Castle ICE controller and motor timing - No apparent effect on current draw?
Hello,
I am the process of setting up a new plane and while playing with the Castle Creations ICE controller I noticed that changing the motor timing had no effect on the current draw while testing the motor. I had expected low timing to result in lower current draws while the high setting to result in higher current draws. As far as I could tell, they behaved the same way. The motor in question is an AXI outrunner. In the past, when using Jeti controllers I could fine tune the motor current draw (if needed) by altering the timing. Any ideas?
Teo
