RCU Forums - View Single Post - YS-170CDI Flight Report
Old 06-03-2010 | 12:35 PM
  #536
MTK
Default RE: YS-170CDI Flight Report
ORIGINAL: rcpattern
Matt,
You are right, I'm running Ed's IBEC's and couldn't be happier with it. I usually stop flying at around 7.5 under load also, however on my old Li-Ion they always said the no fly voltage was 6.9 although I never went that low. I have dual 900mah LiPo packs that I run, and I can comfortably get 4 flights in one day and only put about 400-450 back in each pack, so I'm using around 200-225mah per flight (10 minutes of flying), this includes the ignition, RX, and servos..
Arch
Okay so ours are roughly equivalent set-ups in regard to battery capacity. You use two 900s in parallel and I use one 1780 straight up. I don't check mine under load usually....it is 7.5 V unloaded (and around 7.2 loaded with 1 ohm load the couple times I did check it loaded). I may be drawing more out of the battery than I should be.
thanks for the input
