RE: Beginner solderer
To avoid overheating when soldering it is important that you use an iron that is large enough.
Whilst this sounds backwards, a large iron will get the area you want to solder up to temperature quickly. A smaller iron will take longer, and all the while the heat is conducting away from the joint to the surrounding area.
Terry
