Ultta hots has pull-pull
My Ultra Hots has pull-pull for both the elevator and rudder. I set up bell cranks to take up the tension of the pull-pull system. Then I used a short push rod from the servo to the bell cranks.
I have run pull-pull systems before directly to the servo arms. I like the bell crank method because I feal it takes some stress off the servos.
tonyc
