RE: First Tiger finished
Hi chaps
Ive tried pushing them out with exactly that type of thumb tack thingy with no joy...... saying that, I can always try again!
The idler(s) is(are) a hassle. The bloody axles that came with the hull were way to long. Ihave half a dozen washers in there and its still loose. The two sides are (were) stuck with glue but they popped.
The big issue is that while Ican shove more washers in there....I am unsure if that leaves the idler positioned correctly?
Or am Igood to go once the inside edge of the idler is up against the suspension bar (you know what Imean Ihope)?
p
