RCU Forums - View Single Post - Engine Won't start
Old 07-21-2003 | 07:31 PM
nafai1
Default Engine Won't start
Thank you all for the suggestions so far...
Here's a couple of things...
To vegassky:
I will try again to empty the cylinder, perhaps I just didn't get it all out before.
To Montague:
I did get the engine started once. When I did, the prop moved quite freely and fired up. After I did, I ran it at full bore to break the engine in per manufacturer's instructions.
I'd add a second jam nut to the shaft, but it's too short, unfortunately...I was thinking of dropping a lockwasher on there to see if that helped.
I'll also try the chicken stick trick.
To autopilot:
I am extremely new to the R/C world-most of the time, my forte is computers
I have the prop stuff attached to the shaft in the order you describe, so that's most likely not the issue...
I don't understand your question about the engine being "inverted". What does that mean?
I actually have to pull the fuel tank out when I refuel (major pain in the butt), so I don't think that's the problem either.
Thanks, all for the help so far...
