RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
I'm setting up my first 50cc plane using a Hitec Aurora 9 / Optima 9 system. How do you go about programming a choke servo as "on/off"? Is the set-up the same for an optical kill switch? I'm assuming this is done via a P-mix in order to activate a switch once it is assigned, but I'm stumped on the best method of programming this.
Thanks in advance,
Chris
