RCU Forums - View Single Post - Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Old 06-06-2010 | 04:00 PM
  #59
A.T.
Default RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
ORIGINAL: notruthless I'm setting up my first 50cc plane using a Hitec Aurora 9 / Optima 9 system. How do you go about programming a choke servo as "on/off"? Is the set-up the same for an optical kill switch? I'm assuming this is done via a P-mix in order to activate a switch once it is assigned, but I'm stumped on the best method of programming this. Thanks in advance, Chris
Not sure on interpretation of "choke servo"
To set an on/off switch to drive a servo from one fixed position to another =
Settings >System >Channel >(unused Channel say "Ch7 AUXx:NULL") >NULL >SEL >[Channel Control Select] two position switch say "G" > SET. Return to main menu or turn Aurora off.
Otherwise for variable position, assign a slider in lieu of switch
see also manual page 68.
<font size="1">Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
</font>
Regards
Alan T.
<font color="#22229c">Alan's Hobby, Model &amp; RC FAQ Web Links</font>
