RE: Engine Mount Safe?
I would use that mount as is for years.
It is crack due to over-compression of the bolt.
That engine will not produce more thrust than 5 lbs; @1.25 each bolt.
If it worries you, due to vibrations, you could wrap it with fiberglass cloth and epoxy.
