I have 2 OS-55's and they both ran poorly at mid throttle untill I leaned the low speed needle about 1/2 turn. After you get the high speed set then adjust the low speed till the engine runs smoothly at low and mid throttle. I have seen this on at least five other OS-55's.
I am actually using a 12/6 on the Spot On and 11x7 on the other plane. Both APC props.
Sorry about the crash[&o]. At $149.00 it's probably cheaper to replace than rebuild[
]? It's a great flying plane.
Good luck.
