RCU Forums - View Single Post - Titan Kero start issues, Need Help..
Old 06-07-2010 | 10:27 AM
BaldEagel's Avatar
BaldEagel
Default RE: Titan Kero start issues, Need Help..
If you need more amps to suppliment your Kero start and have the new enclosed IO board you can plug an external battery into the charge socket for start up and then use the on board battery for flight, I use a three cell A123 with a modified ECU to accept the voltage and have never had a failed start due to the battery.
Mike
