ORIGINAL: Aussie_Knife_Edge
Hi Paul,
I think many people have issues with getting correct numbers out of that sensor me included. This is why Joe is asking for details of how you have it set-up. Your results look plausable whereas results from my brushless RPM sensor are up in the 64,000 RPM region whis is way off. And yes, the SW has been set to the correct number of poles...
Cheers
Jason.
Wait a second here!
I use the same sensor. Are you implying my motor is not getting to 64,000RPM!
I thought I found the perfect prop, motor, batt ,esc combo!
BTW Jason,
Did changing the settings fix this??
Thank you
Mike
