Sunday saw the combat debut of my SU-85
Its a bit of a last minute lash-up using an RX-13, DBC and an ARM-01b flash/recoil blocker - the IR emitter is fixed in place in the drivers hatch, but it works well enough on semi level ground
Best of all the IR apple is a good inch and a half lower than on most tanks, which causes the other team to aim high and miss! [>:]
Also had a new building and a few more trees out on the field:
