RCU Forums - View Single Post - C30 setup for beginning
Old 07-22-2003 | 12:56 AM
randy41
Default C30 setup for beginning
Originally posted by mlcasmey
The manual recommends +65. What does that mean? It it just a number that represents how much total movement you get in pitch? Thanks, Mike.
That quote is correct. With that being said. lets say you
lowered the +65 swash pitch setting to +50. This would
give you a over all softer pitch.
Example: +65 swash setting might give you -4 +8 +11
from low collective to full collective. +50 swash setting might
give you -1 +5 +8 from low collective to full collective.
This is leaving the pitch curve at default 0 25 50 75 100.
Just use the 5 point pitch curve. You know how to do that.
