RCU Forums - View Single Post - C30 setup for beginning
Old 07-24-2003 | 08:09 AM
Vortexgen
Default C30 setup for beginning
careful with off or 0% sens on a gyro. sure if your moving forward fast its not a big deal but most experts only reduce the sens enough to stop the tail from hunting. somewhere aound 30-50 is good enough to stop the tail hunting in forward flight in most cases.
for faster piro rates, simply use programmable mixing with rudder as the master, gyro as the slave, stick position as the switch.
This effectively means as you move your rudder stick away from the center (left or right) the gyro gain is reduced. The amount of reduction is programmed in the mixing. Most modern radios have this function available.
Yes randy, there are many ways to accomplish the same task.
In saying that, Im sure as soon as you begin using idle ups yourself, you could rapidly change the advice you have been giving. Great to see that you are always happy and doing your best to provide the most sincere advice you can, and Im sure everyone thanks you for it, including myself.
Keep it up.....
