RE: Elan Has Arrived!
Hi Mike,
The new Reactions looks much better than the old ones. What I really want is the A-4 from Tam but I would need to buy another Turbine. You can only use a P-70 on his and unless the grass is "real" short, it needs to fly off a hard surface. Any way, I like a lot of wing loading. Things are a little tight right now and I shouldn't even be thinking about another Jet but I don't want to go through the Winter with out building. You know how that is.
Doc...
