RE: Elan Has Arrived!
Doc
We are only at the begining of our season, it should be too early to be building, unless you have to LOL.
Solved the pump cabling problem, I drilled a 1mm hole through the brush holder and then opened it out to 3mm this allowed the insulation to go into the back plate, I then soldered the cables straight onto the brush arm, it worked so well that I did my spare pump as well, never did like the cables only being supported by the copper brush arm, soon as I am back on my Desktop PC I will post some pics. Also salvaged all the servo's out of the Elan, the main damage is to my 6014HS Rx and the Orbit power Jack, looks like both are not salvagable, well not by me anyway.
Mike
