RCU Forums - View Single Post - Gasket material for PeeWee conversion?
Old 06-08-2010 | 03:01 PM
Mr Cox's Avatar
Mr Cox
Default Gasket material for PeeWee conversion?
Does any one have any advice on what gasket material to use in converted PeeWees?
The teflon ones get pinched of right away so I've tried using a thin aluminium one from a soda can. I got several good runs in today, getting about 10000rpm on a graupner 6x3 when fully leaned out, and the engines sounded really strong. That's on my regular diesel fuel with 33% ether, 25% castor and 1.5%DII, so nothing special, and had very easy starts when priming the piston.
But eventually that gasket was broken too, after about 4-5 tanks. I'm not sure that it gets pinched of, it might actually get bent off (?) right next to where it is clamped. Any ideas? Thicker aluminium or brass instead?
