RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 06-08-2010 | 07:12 PM
  #1062
MTK
Default RE: SAP 180 (Syssa Performance)
I received the NerdLocks and Ultra Copper Permatex this afternoon.
After cleaning bolts, holes, and making sure everything was flat, I re-assembled with a thin ally gasket I made from flashing. Gasket was Ultra Coppered in. Tightened the bolts to about 100 in-lbs (per Todd).
Permatex takes 24 hours to fully cure so I should be set for the weekend. Up to now, I couldn't get 3 flights without the header loosening. The evidence on my set-up was lots of oil residue on the bottom of the stab (there should be none if the header holds tight)
