Pull-pull action: slight position sticking
I'm wondering if the holes on your control horns on the elevator aren't lined up with the hinge line exactly... If the holes are forward of the hinge line, the lines will get tighter thru the movement. If the holes are behind the hinge line, the lines will get looser thru the movement.
My guess is you can loosen the tension a little and the problem will go away.
