all dx6 i pros, need help
Got new dx6i with 6200 rx and a 6110e rx.
Hooked up to cp3. Followed Marc's video on binding dx6i.Bound tx and rx.Put name in cp3. Motor disconnected. Went to power up, wouldn't arm. Must have broke esc when trying to pry esc and rx apart. Put esky rx back in, same result. How do you get the name of a heli out or change it in the tx?
Went to hook up belt. Disconnected motor. Bound tx and rx. Put all connectors in by Marc's video. Reset throttle end points.Only 2 of the 3 head servos would move. Where does pitch servo go? rx only has aiel, elv and rudder. Those worked fine. Couldn't figure it out. Put esky rx back in. All was good in normal mode. hit idle up and swash dropped anout 15 degrees in front. I just flew it 3 days ago with esky tx. All was good.
Need photos of wat goes where in the rx on both planes.
If i can't get this figured out, I'm trashing about $600 worth of planes and just flying my HBV2.
