RE: all dx6 i pros, need help
it sounds like you just need to connect the third servo. one aileron servo goes to the aile, and the other to the aux slot on the rx, and elevator goes to elevator. go into the adjust list and make sure the swash type is set to 120 degrees. if you have'nt changed anything but the rx, then everything should work the same as before. if it is not setup properly, then you should check out the finless bob vids on setting up the swash mix, so you can get the servos going in the right direction. these are are superb videos for understanding basic setup for 450's. as far as the model name, you can go back to the setup list and click on it the same as before when you put the name in and you can scroll through, click on each letter and change the name or go to the blank space for each letter and erase the name. you dont want to go to the reset option in the setup list, unless you want to reset all the settings for that model memory. this time when you get the rx's hooked up right and disconnect the motor, make sure your throttle is all the way down, and also make sure the throttle trim is between mid stick and low before you try to arm it..................td
