RCU Forums - View Single Post - Programming 10CHP
Old 06-10-2010 | 07:05 PM
Cashpoboy's Avatar
Cashpoboy
My Feedback: (7)
Default RE: Programming 10CHP
I am not sure what you mean 'model' setup. The only thing I can find is in the parameter menu and it shows different wing setups for gliders. There is only one acro setup for the kind of airplane I am flying.
Once I figured out that you set it up with ailerons on 1 & 7 and flaps on 5 & 6 it all came together.
This information is buried in the 10C manual about half way through and not easily found.
Futaba should set up this manual differently. They should start with what kind of airplane you have and then how many servos there are and their configuration.
A flow chart would be most helpful for the average guy.
Instead Futaba shows many examples of how to change things so you get the hang of it by trial and error.
I am a layman and this language is confusing as all get out.
