RCU Forums - View Single Post - does fuel choice effect flight time?
Old 06-11-2010 | 05:29 AM
Mr Cox's Avatar
Mr Cox
Default RE: does fuel choice effect flight time?
A fairly easy test is to measure how much you get into the tank when filling it up and then to drain it through the fuel line to se much useful volume that you actually have in the current setup. There might be errors both in the vent position and in the fuel draw/clunk.
If the engine runs well, don't change the setting.
