RE: P60-SE Startup Problems
It is propane start. We test-ran the engine in the airframe, not on the bench.
I didn't check the EGT, only the last max RPM. I'll check the EGT if it happens again. Are you thinking that the EGT might be too high, and that that's what's causing the shutdown?
