RCU Forums - View Single Post - Programming 10CHP
Old 06-11-2010 | 10:53 AM
Cashpoboy's Avatar
Cashpoboy
My Feedback: (7)
Default RE: Programming 10CHP
Thanks Bax
I am a diehard Futaba fan.
The more I play with this thing the better I get at it.
Just a heads up in the 10C manual.
The switch logic function instructions in the manual make absolutely no sense to me.
Not even sure what this does. I am fairly certain I want to use it for idle-down and throttle cutoff.
I know what I would like for it to do but the manual is vague at best.
Would like for 3 way switch 'C' to be used. If 'C' is up, idle down off. If 'C' is middle, then idle-down on, but no engine kill function. And with 'C' down, idle-down is on and allows engine kill with switch 'F'.
If you could describe settings for me I would be grateful.
