RCU Forums - View Single Post - Sig Citabria Build
Old 06-11-2010 | 06:06 PM
  #50
Sketchin
Default RE: Sig Citabria Build
Hey Starwolf, really enjoying reading about your Citabria build! Ihave been building the same one off and on for almost 2 years now (eek!). I am actually stuck on mounting the servo into the wing. Iam doing the bellcrank method, same as you, and can't figure out how you would mount the servo and still be able to service it in the future (if need be). The instructions mention something about a servo mount which Inever got, and the plans say something about using hardwood mounts that aren't included. Making them would be no problem at all, but you would have to screw the servo down first, and then glue the mounts into the wing and have the screw heads running towards theleading edgeof the wing. Anyway, I will be keeping an eye on your thread and patiently wait for you to get stuck in the same spot!
Cheers
