RCU Forums - View Single Post - Fuel usage problem.
Old 06-11-2010 | 10:57 PM
dakotanut
Default RE: Fuel usage problem.
I tightened down everything on the motor. I found that the exhaust manifold that attaches to the motor was loose. Only problem, my spin starter battery went dead so I can't start it. It's charging now. I set the needles back to stock and when I can start it up and check it I will. The head was tight, the carb is tight, no holes or anything in the fuel lines. They are tight also.
