ORIGINAL: AlienModified
I'm hand building an aluminum rod chassis, so driveshaft length shouldn't be an issue. And I think I will have to get the steel gear set, plastic will probably shred under the weight of the aluminum chassis and .040 aluminum body.
Thanks for the info!
The stock axle gears are aluminum.
