RCU Forums - View Single Post - Aftershock 8E reverse problems
Old 06-12-2010 | 07:58 PM
basketballfan60123
Default RE: Aftershock 8E reverse problems
ORIGINAL: UrcHobby
Hey Jorge Take a look at your throttle trim. Make sure when the car and remote are in neutral position that there is no light lit on the ESC. If there is turn the trim till the light goes out. If the trim is off you will loose reverse.
Thanks Kurt;
I am not to familiar with those trim controls on the remote when it comes to adjusting an electric but your solved the problem; all I need now is some screws with those bushings or whatever they are (BS903-017) like the ones in the picture.
Do I have to order the entire part to get some extra ones; probably right?
