Thanks guys. I didn't work on this one today but did get to test the aluminum brazing on another project. It did very well on just a MAPP gas torch, that's 1/8" brazed to some metric thickness shock tower, probably 2.5mm. I tried to bend/crack the joint and the tower bent away from the joint. I should try some butt and T joints to really test it's bonding strength.
