problem with recomended CG ? HELP !!!!!!
Try balancing at the point on the wing that is in line with the main spar. See if that's close to balance to some of the other suggestions you've had (eg. 25-30%,etc.) If you start at the main spar you won't be a large amount off. Then you can make minor adjustments (nose or tail) from there.
