RE: Ryans Rebel Build Thread
After I glued in the H-stab mounting plate I checked to see how level the stab was. It was off a little bit but after a little sanding it was straight as an arrow.
After checking that, I moved on to epoxying the hardwood corners in behind F1 and adding the triangle stock in all the proper locations. Also glued in the LG block and epoxied the tank floor.
