RE: shop ideas
Get the height of your worktable[s] right for you. Decide if you work standing or sitting most of the time before you do this.
Set up an extractor fan system to provide positive extraction ventilation where you will be using cyano and epoxy. THIS IS IMPORTANT !
Have a hole in the back corner of your building bench with a trash can beneath it.
Get an old chest of drawers and put it to the right of where you will work. Assuming you are right handed. Storage.
Get a couple of magnetic knife bars and put them under a shelf above your main work area. Ikea do cheap ones.
Have an anglepoise lamp set up over the building board and a some ceiling lighting above the board.
