RE: Running In
The biggest problem is heat from running too lean especially with all synthetic oils. The temperature of the liner surface (in particular) can get high enough to boil off the oil film which leaves no lubrication for the piston. Also a very lean run sends the temperature of the wrist pin above the boiling point of synthetics so the rod runs dry on the wrist pin. Some castor can help for a short time.
