RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
You are seeing midrange movment in the air or on the bench?When Itry it on the bench Isee either the surface position from the stick or fail safe (trims) 1 second later.
Some day with an old plane high up Iwill be brave enough to turn off the TX and really test it! Maybe pull a loop and at the 45 degree up postion do the on/off and pray: "Hitec don't let me down now"!
