RE: Co-Comanche
I guess I should have mentioned that, the blades are balanced and tracking properly. Main problem is the forward flight, almost non existant. Push the cyclic forward all the way, heli slowly moves forward several feet then stops and rolls to the left. Even with you holding the cyclic dead center full forward. Basically push the cyclic straight forward, heli moves slowly forward several feet stops then rolls to the left? NOWIND and inside. Now on the other hand left right and backwards it will go like a bat out of **** you barely move the cyclic backwards left or right and it moves quickly like it should.
