RCU Forums - View Single Post - Black Magic VF3 E build thread!
Old 06-14-2010 | 03:37 PM
  #124
grantb
Default RE: Black Magic VF3 E build thread!
ORIGINAL: petec
Looks good, you have a lot more patience that I do given your plank sheeting on the nose. I did all my Black Magics with 3 pieces of 1/8'' that I wet down to bend over the radius.
Shiraz is always good when I run out of Cabernet. I wonder if that label is available in the States?
Not patience Pete, I'm just following the instructions!!! Like I was told to I've updated my previous post with US supplier details if you run out of Cab. Foam stabs with half ribs are 20g (.7oz) a piece. The sheeting, cut to size, is another 20g per side. Foam stabs sheeted, trimmed with lightening holes and glue should come in around 80grams (2.90z) My projections show that my batteries will be hard up against the firewall. I need to lighten the tail as much as possible to try to move the packs back.
Where is your battery tray located?
