RCU Forums - View Single Post - throttle adjustment problem
Old 06-14-2010 | 06:07 PM
rcacro
Default RE: throttle adjustment problem
ORIGINAL: 3daerofly
Flew it twice today. The throttle response was definitely better but still was not perfect. Right now, I do have it set on the innermost hole on the the throttle servo and farthermost hole on the carb arm. I might add another linkage to see if that helps. Would adding some sort of extension to the carb arm help? The outermost hole (actually the only hole) is just less than half an inch out. The carb arm is not adjustable since it has a notch in it.
Yes adding an extension to the arm will help.It will allow you to select /drill a hole at an optimum point.
Use the "throttle curve" in the transmitter for the final adjustment ofthe response of the throttle stick.
