RE: Co-Comanche
Hi,
... if your flybar is not level when the blades are level, why are you surprised the heli moves in one direction if you push straight forward? Did you ever check if the flybar is balanced? (I once had one where one weight was considerably lighter than the other.
Also, is your flybar link long enough? If the flybar leans to one side, that might be the reason. Check and extend if necessary. to get more forward movement, you may want to go one hole further out on the servo horn ... if you got the factory cut down horns, get a set of new horns (EK2-0500A/000491)
Hope that helps
