Duraplane bipe????
OK, so you've got the two frames joined together by four wood dowels (one on each corner) The dowels stick out each side, the bottom dowels are used to secure the frames to the fuse in the same way that the wings are secured. You could wrap the bands around the bottom of the fuse to make it more secure.
You then slide the bottom wing through the frame so that it rests on the fuse, connect the aileron servo and band it down in the usual way.
Just place the top wing on top of the two frames and band it down to the top two dowels....
If you make the frames correctly, It'll be secure but will pop apart in the event of a crash.... and of course will be easily removable for 'normal' flight.
