RCU Forums - View Single Post - throttle adjustment problem
Old 06-14-2010 | 06:56 PM
john josey
Default RE: throttle adjustment problem
ORIGINAL: 3daerofly
Flew it twice today. The throttle response was definitely better but still was not perfect. Right now, I do have it set on the innermost hole on the the throttle servo and farthermost hole on the carb arm. I might add another linkage to see if that helps. Would adding some sort of extension to the carb arm help? The outermost hole (actually the only hole) is just less than half an inch out. The carb arm is not adjustable since it has a notch in it.
Is it possible to post a picture of the carb/throttle arm ? there is just something that doesn`t seem right. Did you get a chance to have a look at the quick tutorial that i did on the other thread with the link that i posted ?
cheers
john
