Yes, it's very critical. The moment you lift off the ground weighing more than 55 pounds, the Earth's magnetic field will reverse, and a time/space wormhole will appear at the spot you broke ground. All life as we know it will cease to exist, being instantly sucked into a vortex that time itself cannot escape.
Or...
You can file for that experimental certificate them other guys told you about and all is good again.
