RE: does fuel choice effect flight time?
The low end setting is probably your culprit. Do you get a lot of residue on the side of your plane? An engine rich on the bottom will blow raw fuel out of the muffler when you gun it from idle of just off idle. It'll also constantly spit fuel when cruising at low throttle settings.
