ORIGINAL: lez1troubles
Hi Spinnerrow, check out POWERHOUSE PERFORMANCE, he does some real nice port work, if you look closely at the photos of the work he has done you should be able to get a rough idea of what to do, other than that a good exhaust set up is the quickest way to gain power without screwing up a good engine.
Just a silly thought, have you ever tried using car fuel +/- 20° nitro just to see if that'll make your plane go faster???
I thing the fly boys use 5°-10° but aint to sure on that.[8D]
Thanks! I checked out the
PowerHouse site. I got no where near as aggressive on the boost and transfer ports on mine. I might try that on a ringed Super Tigre G-51 I have since I won't have to worry about dorking up the plating on the liner!
The crank work he does is sick!
