RCU Forums - View Single Post - DX7 - dual aileron programming??
Old 06-15-2010 | 08:41 AM
Steve Steinbring
Default RE: DX7 - dual aileron programming??
Go to pg 39 in your DX7 manual you will need to activate the flaperon feature. It will require two channels to program dual ailerons without the use of a Y cord. You will be using the aileron channel and the AUX 1 channel to do so. see pages 40 & 41. Once setup you can adjust and fine tune the control surface throws by using travel adjust see page 50 of the manual.
