RCU Forums - View Single Post - Rudder rehingeing
Old 06-15-2010 | 12:14 PM
mclina's Avatar
mclina
Default RE: Rudder rehingeing
Conventional wisdom says that if you put a new CA hinge in place of an old one, the CA will not soak into the wood because it is already CA'd. If you've pinned it and it seems strong, then you are probably fine. Just keep an eye on it.
Good luck
