ORIGINAL: jeffie8696
Unfortunately not all engines respond the same but you did find 400 free RPM. You may need to open up or at least polish the carb throat to gain enough flow to compliment your port mods , that and the exhaust may be restricting it also.
I will take any free 400 rpm I can get any day.
So tell me, does it run ''better''? More responsive? Crispy, like we used to say at the dragstrip?
Yes but I had changed a couple of things. I had been having flame outs while advancing the throttle from mid to WOT and today I got the low end about as lean as I could get it without it dying but I was having lots of trouble with the Merlin HD2003 (long reach heavy duty hot plug) plug I had put in it. the 60NX did not like this plug - AT ALL. My first hint was when it started to run in a way I have never seen a plane motor "run" before. I start this engine with a chicken stick and after I primed it, closed the throttle to just above idle, I flipped it once. It hit, bounced off the compression stroke and went backwards, bounced off the compression stroke and went forward and it stayed "running" like this for a good 50-60 iterations as I looked on in bewilderment. So I guess it was a 1.5 stroke engine at that time. I flipped it again and it hit hard against the stick. Another flip and it started backwards and as I closed the throttle it started running forward nicely but as soon as I took the glow starter off it died. Started it again and ran it up and it stayed running but obviously didn't like the plug. I stopped it and put in a Merlin HD2002 (long reach medium heavy duty) and the motor was transformed. Very snappy response with no mid range sag during throttle advance. With a 10x8, this motor has near instant throttle response any way before and after the mods but I was digging the way this thing was running. I just love this engine. The stock muffler is absolute, 100% garbage so you have to spend the extra cash to get a better exhaust but with a Macs pipe or the EVO/Jett muffler it is a hoss. Not bad for the $124 I paid for it. I'll get another one soon to put it on a little Rookie club racer I have a 46AX on currently.
By the way, I was running 15% Omega Aero with 18% castor/syn oil.
ORIGINAL: summerwind
convert it to Spark ignition......that'll make some serious RPM's
Thanks again. Your wisdom is much appreciated but why convert it when you can just buy one
here - The new Magnum Gas XLS-52.
