Mixing smoke pump to throttle ?
I'm sorry for the delay, but I have been out of the office for the past week. To set that up, use a program mix, channel 1 to 5. Then press select until the arrow points at Offset. Then move the throttle stick the position that you want the pump to turn on/off. Then press clear. This should enter a value under offset. Then press select again until the arrow points at Rate, then set the percentage as needed. Adjusting the offset value will adjust the point at which the arrow pointing to each percentage will move from the lower value to the higher value.
