Mixing smoke pump to throttle ?
Yes, you can add the gear switch to the mix, and use it to turn the mix on and off. Just select the GEAR beside SW in the mix. If the mix you are using does not have GEAR as an option, move to another mix. I see that mix 4 does have the GEAR as an option.
